python bigsuds - Device Certificate Info
Problem this snippet solves:
This python bigsuds script prints device certificate information from multiple devices specified as arguments. The script accepts multiple hostnames or IP addresses and can be passed from stdin.
How to use this snippet:
Single host
cert-device.py <username> <hostname>
Multiple hosts
cert-device.py <username> <hostname1> <hostname2>
Pass from File (Linux)
cat bigip-hosts | xargs cert-device.py <username>
Code :
#!/usr/bin/env python
__author__ = 'buzzsurfr'
__version__ = '0.1'
def get_device_certificate(api):
Gets device certificate information from multiple F5 BIG-IP devices.
Prototype
dict get_device_certificate(
BIGIP.bigip api,
Parameters
api of type BIGIP.bigip contains the established connection.
Return Type
dict containing the certificate properties.
return api.Management.KeyCertificate.get_certificate_list_v2('MANAGEMENT_MODE_WEBSERVER')[0]['certificate']
# Standard Library
import sys
import re
# Related Third-Party
import getpass
# Local Application/Library Specific
import bigsuds
if len(sys.argv) < 3:
print "\n\n\tUsage: %s user host ..." % sys.argv[0]
sys.exit()
# Get login password from CLI
userpass = getpass.getpass()
# Store results in variables for all hosts as dict
result = {}
# Iterate over hosts
for host in sys.argv[2:]:
# Connect to BIG-IP
api = bigsuds.BIGIP(host, sys.argv[1], userpass)
api = api.with_session_id()
result[host] = get_device_certificate(api)
# Get console output column widths
space = 2
columns = {}
columns['host'] = max([len(host) for host in result])
columns['subject'] = max([len(cert['subject']['common_name']) for cert in result.values()])
columns['issuer'] = max([len(cert['issuer']['common_name']) for cert in result.values()])
columns['bit_length'] = 4
columns['expiration_string'] = max([len(cert['expiration_string']) for cert in result.values()])
print_string = "%-"+str(columns['host'])+"s"+(' '*space)+\
"%-"+str(columns['subject'])+"s"+(' '*space)+\
"%-"+str(columns['issuer'])+"s"+(' '*space)+\
"%"+str(columns['bit_length'])+"s"+(' '*space)+\
"%-"+str(columns['expiration_string'])+"s"
# Output to console
print print_string % ("Host", "Subject", "Issuer", "Bits", "Expiration Date")
print print_string % ('='*columns['host'], '='*columns['subject'], '='*columns['issuer'], '====', '='*columns['expiration_string'])
for host, certificate in result.iteritems():
print print_string % (host, certificate['subject']['common_name'], certificate['issuer']['common_name'], str(certificate['bit_length']), certificate['expiration_string'])Tested this on version:
11.5Updated Jun 05, 2023
Version 2.0Theo_12742
Cirrus
Joined November 19, 2012
