Proxy pacfile hosting without need for Webservers for v9, v10 and v11
Problem this snippet solves:
The following is an iRule that allows the F5 to serve a proxy pac file to a client without the need of hosting it on a web server or the proxy itself.
Simply create the iRule and associate it to a virtual address running a specific port that has no pools.
Definition
What the heck is a pacfile? Well it's a javascript file that defines how web browsers and other user agents can automatically choose the appropriate proxy server (access method) for fetching a given URL. So you might have specific sites that go through a proxy and some sites that do not. The pac file can do this for you.
To read up more about it you can go to the following links: http://en.wikipedia.org/wiki/Proxy_auto-config http://www.craigjconsulting.com/proxypac.html
Now back to the configuration...
How to use this snippet:
Example
VIP: 192.168.1.20: 80 TCP Domain: Proxypacfile.intranet.com --> 192.168.1.20
Just set your browser up to use the automatic configuration script:
http://proxypacfile.intranet.com/proxy.pac
You can also set to other ports
Example:
VIP: 192.168.1.21: 9090 TCP Domain: Proxypacfile2.intranet.com --> 192.168.1.21
http://proxypacfile2.intranet.com:9090/proxy.pac
Code :
when RULE_INIT {
set pacfile {
function FindProxyForURL(url, host) {
if (isPlainHostName(host))
return "DIRECT";
if (shExpMatch(url, "http://10.*")||
shExpMatch(url, "https://10.*")||
shExpMatch(url, "ftp://10.*")||
shExpMatch(url, "http://localhost*")||
shExpMatch(url, "https://localhost*")||
shExpMatch(url, "http://127.0.0.1*")||
shExpMatch(url, "https://127.0.0.1*")||
shExpMatch(url, "http://172.*")||
shExpMatch(url, "https://172.*")||
shExpMatch(url, "ftp://172.*"))
return "DIRECT";
if (dnsDomainIs(host, ".extranet.com")||
dnsDomainIs(host, ".extranet2.com"))
return "Proxy yourproxy.domain.com:8080";
if (dnsDomainIs(host, ".intrant.com")||
dnsDomainIs(host, ".intranet2.com"))
return "DIRECT";
return "PROXY yourproxy.domain.com:8080";
switch -glob [string tolower [HTTP::uri]] {
"/proxy.pac" {
HTTP::respond 200 content $::pacfile "Content-Type" "application/x-ns-proxy-autoconfig" "pragma" "no-cache"
