LDAP Pool Selection By IP For Mobile Devices
Problem this snippet solves:
Distributes traffic to different pools based on LOGIN-IP address in LDAP request data.
First define the classes (Data Group Lists) as type "Address", adding the appropriate addresses to each.
Then apply the iRule to the virtual server, and it will distribute the traffic to each pool depending on the LOGIN-IP value.
Code :
# Data Group Lists
class AddressGroupA {
"network 10.16.13.0/26"
"host 10.10.10.1"
class AddressGroupB{
"network 10.16.13.64/26"
"host 10.10.10.2"
# iRule Source
when RULE_INIT {
set ::defaultPool myPool
when CLIENT_ACCEPTED {
TCP::collect
when CLIENT_DATA {
set LoginIP [findstr [TCP::payload] LOGIN-IP 9 "MSISDN"]
if {$LoginIP != ""}{
if { [matchclass $LoginIP equals $::AddressGroupA]}{
pool PoolA
} elseif { [matchclass $LoginIP equals $::AddressGroupB]}{
pool PoolA
pool $::defaultPool
TCP::release
}Published Mar 18, 2015
Version 1.0Deb_Allen_18
Historic F5 Account
Joined September 25, 2004
