Advanced TFTP Load Balancing
Problem this snippet solves:
TFTP works in similar fashion to active FTP, using a callback from a random high port for the data stream: 1. The initiating host A sends a request packet to host B at Well Known Port 69. 2. B replies with a packet sent from an ephemeral port, which should be used for the remainder of the request for all data packets between Host A and host B.
How to use this snippet:
To support the callback connection, you would: 1. Configure the UDP virtual server on port 69 to accept the control connection and apply the clientSideTftp 2. Configure & apply a SNAT enabled at least on the server-side VLAN 3. Configure the UDP virtual server on :any 4. Apply the serverSideTftp to reestablish the auto last hop context 5. Build a data-group for all possible vlans the clients can connect to similar to vlanMapping
Code :
rule clientSideTftp {
    when CLIENT_ACCEPTED {
        set LAST_HOP_MAC [LINK::lasthop]
set CLIENT_VLAN [LINK::vlan_id]
        set CLIENT_IP [IP::client_addr]
        set VIRTUAL_IP [IP::local_addr]
    when SERVER_CONNECTED {
       table  set "[LINK::vlan_id][IP::remote_addr][IP::local_addr][UDP::local_port]" "$LAST_HOP_MAC $VIRTUAL_IP $CLIENT_IP $CLIENT_VLAN" indefinite 3600
rule serverSideTftp {
        set entry [table lookup "[LINK::vlan_id][IP::remote_addr][IP::local_addr][UDP::local_port]"]
        if { $entry ne "" } {
   nexthop [class search -value vlanMapping equal [lindex $entry 3]] [lindex $entry 0]
   snat [lindex $entry 1]
   node [lindex $entry 2]
data-group vlanMapping {
    external-file-name /config/vlanMapping.dat
    records {
        1100 {
            data peering
        1101 {
            data external
    type string
Tested this on version:
10.2
Published Jan 30, 2015
4 Comments
  • Hi Team,
    I am no vice in setting up the data group, please let me know how to setup the external file for data group. I am trying to build a TFTP VIP and i am unable to understand the provided steps.
  • Jana's avatar
    Jana
    Yes, it requires two vips
    ltm virtual vs_tftp_loadbalancing_69 {
        destination 172.16.4.101:69
        ip-protocol udp
        mask 255.255.255.255
        pool p_tftp_loadbalancing_69
        profiles {
            udp { }
        rules {
            rule_tftp-clientside
        source 0.0.0.0/0
        vs-index 353
    ltm virtual vs_tftp_loadbalancing_any {
        destination 172.16.4.101:0
        ip-protocol udp
        profiles {
            udp { }
        rules {
            rule_tftp-serverside
        source 0.0.0.0/0
        vs-index 355
