imac_105647
Jan 06, 2010XML comment triggers an attack signature
Hello,
Can anyone tell me why a comment in an XML POST is seen as an attack?
The only thing I've found so far is the use of comments to help generating the correct checksum on signed content.
Here is a sample of the troublesome XML, take out the comment and the problem goes away:
1972-05-01
Employed
M
false
This triggers the attack signature:
Comments (2) 200016001
- hoolio
The Comments 2 attack signature is matching on XML/HTML comments as comments could potentially be used to obfuscate attacks. If your app accepts / requires comments in the XML, you'd want to disable this check either for the entire policy, just one object or a single parameter if the XML is passed in a parameter.
If you'd like more details on the logic for including this signature in the attack sigs, you could open a case with F5 Support.
Aaron
