SomeGuy_75758's avatar
SomeGuy_75758
Dec 11, 2009
X-Forwarded-For with FirePass
Is there some way to enable XFF headers using FirePass? If not, can this be accomplished using a SED script or some other method?
My goal is to have the client ip to show up in our IIS logs instead of the FirePass's internal ip. I have found the ISAPI filter for IIS already.
Any suggestions would be greatly appreciated.
  • I believe you can do this with Big-IP (i-rule), never seen this done on the Firepass.
  • Can't help on the XFF bit, but maybe there is another way to pass the IP to the server... The client IP is recorded in a session variable on the Firepass. Maybe you could incorporate that variable in the Firepass favourite (maybe tag it on at the end with &IP=%session.network.client.ip%), and have IIS extract it. But it would only work for the initial connection, not every HTTP transaction.
