access2AE_25064
Dec 25, 2016X-Forwarded-For to send information other than Client IP
We are kind of stuck while implementing a solution.
We need to send Client SSL Certificate common name from BIG-IP to the Middle-Tier server. I read in google that X-Forwarded-For send only Client IP.
Is there any header other than X-Forwarded-For which can send information(in our case its Certificate common name) to the MT server?
Your help would be much appreciated.
Regards, Prabir
- nathe
Cirrocumulus
Check out this post, it should help.
https://devcentral.f5.com/questions/insert-common-name-value-to-http-header
N
