Doran_Lum_13484's avatar
Doran_Lum_13484
Sep 04, 2017
X-Forwarded for https
Hi all, we have an application on our server which can't determine if the request is https or http coming from F5. X-Forwarded option have been enabled but the issue still persist. Should
I have try with the irule below for X-Forwarded-Proto but somehow I got an error.
I have also try to insert "https" for Request Header Insert but the issue still persist.
  • HI
    you miss
    in end
        if { [ssl::mode] == 1 } {
            if {!( [HTTP::header "x-Forwarded-Proto" ] eq "https") }{
                HTTP::header insert x-Forwarded-Proto "https"
            if {!( [HTTP::header exists "x-Forwarded-Port" ]) }{
                HTTP::header insert x-Forwarded-Port [TCP::local_port]
    have a good day!!!
  • Hi Doran,
    you could streamline your iRule by moving the protocol enumeration into the
    CLIENT_ACCEPTED
    event (triggered only once every TCP connection), store the enumeration result into a
    $variable
    and then reference the
    $variable
    on every subsequent
    HTTP_REQUEST
    event. This approach will greatly reduce the overhead for Keep-Alive-Connections.
    when CLIENT_ACCEPTED {
        if { [PROFILE::exists clientssl] } then {
            set client_protocol "https"
            set client_protocol "http"
        HTTP::header remove "X-Forwarded-Proto"
        HTTP::header insert "X-Forwarded-Proto" $client_protocol
        HTTP::header remove "X-Forwarded-Port"
        HTTP::header insert "X-Forwarded-Port" [TCP::local_port]
    Note: In addition you should review your application if it would introduce certain risks if the client sends handcrafted X-Forwarded-Proto and X-Forwarded-Port headers to your application. If this scenario introduce some risks or if you can figure out the assosiated risks, then make sure to
    [HTTP::header remove]
    any existing
    X-Forwarded-Proto
    and
    X-Forwarded-Port
    headers before
    [HTTP::header insert]
    your verified values...
    Cheers, Kai
