  • what should that iRule do exactly?
    Jason Rahm once wrote a small tftp server in an iRule: https://devcentral.f5.com/articles/tftp-server-via-irules
    if you just want to load balance tftp traffic i don't see the need for an iRule.
  • Hi I have the same issue ! Cannot balance TFTP traffic UDP on 69 as the way of TFTP is working has to be tricked! Is behving like an ACTIVE FTP (Trivial FTP) so he sends initiations of the transfer on the 69 but after the response of the server it will use the ephemeral port used as a source ! Is there a standard way to make it work just by using the tftp profile? The documentation is not clear enough ! Regards!
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      i would assume so, but as you are working with it, just try.
  • ms_g's avatar
    ms_g
    • i would assume so, but as you are working with it, just try.
