Oscar_68814's avatar
Oscar_68814
Nov 27, 2008
Working Irules need a little Fine Tuning
I need some help please.
Our customer wants to have two features on their F5 setup.
A. Limit the connections to a virtual server to say for example 10,000 connections and if this number is exceeded to display a html page with a redirect meta link that will send user to a holding page
B. When customer wants to carry out maintenance work on their servers, they want a message to display such as site is down for maintenance.
a little bit of background first.
Customer is using cookie insert persistence due to their megaproxy, I have configured this no problem and each virtual server will have a http and https access method but using the same pool members.
Please see below the two irules I have configured for scenarios 1 and 2.
My questons are
1. Will this work for cookie insert persistence
2. How can I configure html content that can include color, meta links etc. I have tried but F5 code will not let me, I can only write simple html pages
Many thanks for your help.
1. Connections Limit
when RULE_INIT {
set ::total_active_clients 0
set ::max_active_clients 1}
log local0. "HTTP connection limit rule triggered from [IP::remote_addr][TCP::remote_port] to Virtual Server [IP::local_addr][TCP::local_port]"
; If persistence cookie already exists,
; allow persistent connection without incrementing counter
if { [HTTP::cookie exists "BIGipServerseatwave"] } {
use pool xxxx.com
return
if { $::total_active_clients < $::max_active_clients } {
incr ::total_active_clients
use pool xxxx.com
return
; otherwise redirect
HTTP::redirect "http://www.xxxx.com/"
return
when CLIENT_CLOSED {
incr ::total_active_clients -1
2. Load Balancer Fail
when LB_FAILED
{HTTP::respond 503 content "
Site is down for Maintenance, Please try again later
Please update your links.
