JEREMY2's avatar
JEREMY2
Aug 03, 2025
Wireshark Plugins and Filters
Hi Everyone,
I just wanted to inquire if you have any recommended Wireshark plugins, profiles, or appearance settings that could help make packet analysis and troubleshooting easier, especially when working with F5-related traffic.
I tried to access the following page for guidance, but it seems to be no longer available:
https://community.f5.com/articles/getting-started-with-the-f5-wireshark-plugin-on-windows
If you have any suggestions or internal tools (such as profiles, coloring rules, or dissectors) that you recommend for improving visibility and analysis efficiency, I would greatly appreciate your insights.
Thank you so much.
  • Hi
    Adding a command i usually using for creating packet capture(tcpdump) 😉
    tcpdump -nni 0.0:nnnp -s 0 host xx.xxx.xx.x and host xx.x.xxx.xxx-w /var/log/filename.pcap
