Michael_Omaljev's avatar
Michael_Omaljev
Sep 22, 2006
will persistance work over non standard port?
I am trying to create a cookie (insert mode) for a setup and persistance does not seem to be working. I have a pool setup with 2 servers.. The pool is listening on port 7025. The vip for the pool is on port 80. Should this work ?
Working with 9.1.1 code.
thanks
  • hoolio's avatar
    hoolio
    This doesn't appear to be related to iRules. I would suggest you contact support for assistance with this issue.
    https://websupport.f5.com/csp/welcome.asp
    On a side note, yes, cookie persistence should work regardless of what port the nodes are configured on. I did a quick search for persistence + nodes defined on non-standard ports but didn't find anything. A good place to check for known/fixed issues is the latest version's release notes fixed and known issues sections:
    Click here
    You can check what the value of the persistence cookie should be using 'b makecookie NODE_IP:NODE_PORT':
    [root@asm:Active] config b makecookie 1.2.3.4:80
    Set-Cookie: BIGipServer[poolname]=67305985.20480.0000; path=/
    or
    Set-Cookie: BIGipServer[poolname]=67305985.20480.0000; expires=Sat, 01-Jan-2000 00:00:00 GMT; path=/
    This output should match the Set-Cookie header in the HTTP response from BIG-IP to the client.
    Here is the format of the cookie value (from the LTM config guide Click here):
    For example, the following string is a generated cookie template with the encoding automatically added, where [pool name] is the name of the pool that contains the server, 336260299 is the encoded server address, and 20480 is the encoded port:
    Set-Cookie:BIGipServer[poolname]=336268299.20480.0000; expires=Sat, 01-Jan-2002 00:00:00 GMT; path=/
    To create your cookie from this template, type the actual pool name and an expiration date and time.
    Alternatively, you can perform the encoding using the following equation for address (a.b.c.d):
    d*(256^3) + c*(256^2) + b*256 +a
    The way to encode the port is to take the two bytes that store the port and reverse them. Thus, port 80 becomes 80 * 256 + 0 = 20480. Port 1433 (instead of 5 * 256 + 153) becomes 153 * 256 + 5 = 39173.
    Hope this helps...
    Aaron
