Neldien_Musni's avatar
Neldien_Musni
May 11, 2018
What is the maximum number of possible client connections (if there is a limit) to a single GTM/BIG-IP DNS Wide IP?
  • eben's avatar
    eben
    This could be based on Hardware and/or License. I will suggest you get the datasheet for your device model and version.
    HTH.
  • If you check System->License in the Gui it should tell you the number of concurrent connections you are licensed for.
  • GTM license limit is not number of client per wideIP but max DNS requests per second!
    There are 2 different licenses:
    • DNS-1K : limit 1000 rps
    • DNS : limit available on the DNS data sheet (depending on hardware)
