aj11's avatar
aj11
Oct 17, 2017
What is the best way to find and disable/remove obsolete VIPs, pools and hosts?
I'm sure there are reports that show hits and all but is there a collective way to see last hits or frequency, and hosts that are no longer used? I need to get rid of old items no longer in use and am looking for a fairly easy solution. Thanks.
  • Kevin_K_51432's avatar
    Kevin_K_51432
    Historic F5 Account
    Greetings,
    Do you have access to iHealth? There's a pretty cool feature there called Config Explorer which has an Unused Objects section. That might be a great first step?
    iHealth > Config Explorer > Unused Objects
    https://f5.com/support/tools/ihealth
    Hope this is somewhat helpful!
    Kevin
    • aj11's avatar
      aj11
      Thanks. What determines an object is "unused" in this case?
      Kevin_K_51432
      Historic F5 Account
      You're welcome. It appears this is a matter of object association. For example, policies, profiles or pools not associated with virtual servers.
      I found this article which offers a bit more detail:
      K15335: F5 recommends removing orphaned configuration objects
      https://support.f5.com/csp/article/K15335
      Kevin
