What is difference between two cert ?
Hi We need to update cert. but we get two types of the cert: One is ssl-certificate.crt and the second is like the below. What is difference between the two? Maybe after we open the second one with txt, it will become first one, right?
Thank you
-----BEGIN CERTIFICATE----- MIIGnDCCByrYSgAwIBAgIQBgtAyOJefqzeioiOJVchgj3pDANBgkqhkiG9adfw0BAQsFADB+ MQswCQYDVQQGEwJVUzEdMBsGA1UEC -----END CERTIFICATE-----
- AJ_01_135899
Not quite sure what you mean, you need to elaborate. What you posted is an example of an x509 certificate in PEM format.
- Samir_Jha_52506
Noctilucent
Please paste the cert cipher text in box & see.
https://www.sslshopper.com/certificate-decoder.html
- eesun_276598
Cirrus
Sorry i was not clear. I attached the second cert. Please see below. Thank you
- Vijay_E
Cirrus
One could be the cert for your domain & anothger could be CA cert.
- DJ_Singh_192109
I don't see the attachments
you got that certificate from someone / some company, ask them i would say.
