What is difference between "Sync Device to Group" and "Sync Group to Device"?
Hi When we go to Device Management -----> Overview, we can see "Sync Device to Group" and "Sync Group to Device". What is difference between "Sync Device to Group" and "Sync Group to Device"?
What Group is this? Thank you
- SynACk_128568
They mean : Sync configuration from specified device group or Sync configuration to specified device group .
- Vijay_E
Cirrus
See this link:
Sync Device to Group Select this option when you want to sync the configuration of the selected device to the other device group members.
Sync Group to Device Select this option when you want to sync the most recent configurations of one or more device group members to the selected device.
The "Group" is the Cluster of Devices in HA.
- eesun_276598
Cirrus
_"The "_Group" is the Cluster of Devices in HA."**
Two F5 work as fail_text_over. Do we think the Group is traffic group, or traffic-group-1? Thank you
as can be found in those documents the sync is to or from the device group, not the traffic group.
- eesun_276598
Cirrus
Can you tell which F5 represent the Group? Active or standby? Thank you
