what is a volume set for hotfix
I am installing the latest hotfix to address the shellshock bug. when i go to install the hotfix it asks for a volume set name. I have no idea or clue what a volume set is, what to call it, there are 2 options in the pull down, "type or select a name" and "3 (Version:11.4.1 Build:625.0)". i have no idea what the second is but if i try to dup it with the something like "4 (Version:11.4.1 Build:651.0)" it fails. what am i supposed to put in here, the docs are not clear about wat a volume set is.
- daveb_123796
never mind. i was able to just put in shellshock. i tried just enter 5 or HD1.5 to match what i already had but neither worked, so shellshock it is. turns out it names the boot location as HD1.shellshock, where as the others are HD1.3 and HD1.4. So be it. not sure why i couldn't put in % or HD1.5 but i couldn't, so now i have to keep track of which location is what by the build version.
