What interface does the monitoring flow through?
I have a VE F5 v11.6 with LTM and I've created my VS, Pool, and Nodes with ICMP as my default monitor. As long as I don't use any other monitoring (http, https, tcp...) on my pools, everything works correctly however I don't see the status of the pools and VS because they show "unknown" due to no health monitoring. If I add any type of monitoring feature to my pool, the pool and VS flag as the red diamond and traffic stops. I started to look into any possible problems and found that the ICMP traffic from the nodes default monitor was being sent through my Management network and not through the traffic interface that I have setup for the F5. Does all of the monitoring features use the Management interface? I find this odd that the F5 wouldn't use the same interface that is sending the traffic from the clients to the nodes for it's monitoring... If the Management interface is the monitoring interface, can I change it? We have our network heavily locked down, and changing which interface the monitor uses to track the status of the pools would be easier than adding ACLs for all of the nodes through the FW. Any assistance would be greatly appreciated, Thanks
- cjunior
Nacreous
If the monitor is using the mgmt gateway, your traffic will fail even if the monitor state is up. You must create a route to TMOS reach the node via traffic interface/vlan. (e.g. Create route in menu: Network > Routes) If necessary, you can create a default route (0.0.0.0/0) to the traffic gateway and by default, it will have lower metric than default route management, so the traffic will use it out instead of default mgmt. Considers that the Big-IP uses the SelfIP to monitor and FloatIP to flow the traffic (if you SNAT). If you don't have a FloatIP, everything must flow from the SelfIP.
You can test the route from the shell: e.g.
[root@bigiplab:Active:Standalone] config route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 127.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tmm 127.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 mgmt.1 172.20.16.0 0.0.0.0 255.255.252.0 U 0 0 0 mgmt 10.10.10.0 0.0.0.0 255.255.255.0 U 0 0 0 internal_vlan 127.7.0.0 127.1.1.253 255.255.0.0 UG 0 0 0 tmm 127.20.0.0 0.0.0.0 255.255.0.0 U 0 0 0 tmm_bp 0.0.0.0 10.10.10.1.1 0.0.0.0 UG 0 0 0 internal_vlan 0.0.0.0 172.20.16.110 0.0.0.0 UG 9 0 0 mgmt [root@bigiplab:Active:Standalone] config ip route get 20.10.10.1 20.10.10.1 via 10.10.10.1 dev internal_vlan src 10.10.10.10 cache mtu 1500 advmss 1460 hoplimit 64Regards.
I figured out the problem, well at least I know why the wrong default gateway was being used. For whatever reason, the default gateway I created initially never actually updated the F5 configurations. I made a change the default gateway in the Network > Route GUI and after I press updated, the F5 started to send traffic out the Internal VLAN instead of the Management VLAN. This is all working as expected now. @cjunior Thank you very much for all of you assistance. When I ran the route -n command now, I get the 10.21.6.0 network as my default gateway not my 10.2.1.0 network.
- cjunior
Nacreous
Nice, I'm just trying to help friends. Good luck!
