Herman2024's avatar
Herman2024
Dec 02, 2024
Solved
What does "EPS" in ddos threshold setting stands for?
Hi, can someone please help advise what "EPS" in ASM ddos threshold setting stands for? what is the full name of "EPS" ? thanks in advance!
  • Hi Herman2024
    Adding to the other replays , yes it's the event per Second.
    in more details >> It's the event for each vector for example "TCP RST" Vector so EPS here means how many TCP RSTs do you want BIGIP to trigger violation detected or mitigated if traffic reaches to it... i.e "The limit number for TCP RST"
    Measure this on each Vector.
  • Hi Herman2024
  • Hello,
    In ASM (Application Security Manager) DDoS threshold settings, "EPS" stands for Events Per Second
    Best Regards,
    John Dane
  • Hi Herman2024
    In ASM DDoS threshold settings, EPS stands for Events Per Second. It's a measurement of how many packets are received per second.
    BR
    Aswin
