Webtop RDP on Mac Problems
Hi all,
I'm not sure if this is the right category to post the question but here we go :
I'm an end user of a Web Top VPN with RDP as an published App. I'm using this from a mac book with 10.9.x OS on it. Once you click for RDP session launch – it goes full screen and locks you out completely. You cannot minimize the window (no option) or move away to another window to do anything. If I login via a Linux or Windows machine - it works fine but it's just mac which is giving problem.
Also the keyboard mapping seems to be a problem where my Command button on mac isn't giving me a Windows keys response like in Native MS Remote Desktop client.
Any help or work around for this would be much appreciated.
- kunjan
It's known issue. The workaround is to use percent of desktop 100% instead of full screen in window size setting.
- tiwang_122270
hi out there I know it is a stupid idea but it could solve your problem - run a dedicated Windows VM under virtualbox...
When I hit such a problem where it is caused by the platform I sometimes resign and use what is best for the purpose
