MEmin
Feb 04, 2017Websphere deployment issue with F5
Hi, I've a question about Websphere deployment with F5 LTM. Traffic flow is : Public --> F5 Vip (443) --> Poolmembers (9080)
The client request to the LTM (login page with ssl) then F5 takes the traffic to the real servers with configured 9080 port but when the uri changes to the server:9080/A Websphere does not work. I want to change the 9080 port string from the uri path after login page. (server/A) Do you have any suggestions? Thanks.
Use a rewrite profile to rewrite the request and response. (uri-translation)
Set it to both directions and include the client uri: and server uri :
If this doesn't do the trick use a stream profile and this irule (use Kevin's second answer) irule link
Cheers,
Kees
