JSMITH3_342299's avatar
JSMITH3_342299
Mar 12, 2018
web redirect for SSO
I have a site that when you go direct to it, it avoids our SSO tool. I want to redirect from the main URL to the SSO url, but once it has been redirected the host needs to be the same.
Example:
https://pam.example.com/ can avoid SSO - needs to redirect
https://example.okta.com/home/blah/blah/blah
which then goes back to
https://pam.example.com/WebConsole/blah/blah
My rule redirects properly at first, but then grabs and redirects the URL after the SSO sign in again, causing a 404. How can I stop it the subsequent times?
Code:
    if { [string tolower [HTTP::host]] equals "pam.example.com" and
([HTTP::uri] equals "/")} {
        HTTP::redirect "https://example.okta.com/home/example/0oaiosmzv7n2Qipud0x7/alniossou1CNshx5S0x7[HTTP::uri]"
  • Hi,
    Your Authentication System should not only redirect the user back to pam.example.com but also insert an trust or ID or something that we can validate on the Virtual Server. Otherwise, you get redirected to okta again.
    Why not implementing SAML bindings between F5 and Okta ? By using APM module, it's easily done.
    Regards
    Yann
