Travis_Brodeen_'s avatar
Travis_Brodeen_
21 years ago
Web Pool needs cookieless persistence
We have a Web Pool of 3 servers (IIS) that require a persistent SSL connection. Additionally, we would like to employ the SSL Termination features of the BIG-IP System, which offloads the SSL encryption/decryption from the web servers.
As an additional requirement, we cannot use the Cookie persistence to identify the end user, as our web application does not require cookies.
Aside from the Source IP persistence, can anyone confirm (or deny) that it will be possible to load balance traffic intelligently, while maintaining persistence through a custom iRule?
Any examples of this would be much appreciated!
Thank you,
Travis
  • Travis, this looks very much like a product support question. If you need assistance writing a iRule to implement persistence, feel free to post it to the iRules forum. Search for "persist" in the forums and I'm sure you'll find some references.
    For product configuration questions, I'd suggest you contact F5 Product Technical Support at http://www.f5.com/support/.
    -Joe
