VirtouZ_165395's avatar
VirtouZ_165395
Oct 13, 2015
warning: [variable reference used where variable name expected][${var}]
Hi All,
When performing a tmsh load sys config verify, I have the following warning message:
/Common/irule_reverse_proxy_v4.1:90: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:93: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:100: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:108: warning: [variable reference used where variable name expected][${var}]
The block responsible for these warnings in my iRule is:
89   foreach var { "do_host_rewrite" "do_requests_rewrite" "do_responses_rewrite" "rule_debug" }
90   {
91      set ${var} 0
92      if {[class search $datagroup equals $var]}
93      {
94         set ${var} [class match -value $var equals $datagroup]
95      }
96   }
This is NOT https://support.f5.com/kb/en-us/solutions/public/14000/500/sol14531
I tried the iRule with different version (11.6.0, 11.5.3 etc.)
Is there something wrong with my syntax?
Thank you in advance for your help,
Regards,
  • Hi Vitouz,
    the right set command is:
    set var 0
    or
    set var [class match -value $var equals $datagroup]
    the
    is to get value of the variable, not to set it.
