VPN--SSO not working for on mobile devices if SSL offloading is enabled on VIP
We have F5 4000 appliance , configured with two partitions and route domain.One is used for VPN and another for Load balancing.
Configuration
Load Balancer - We are doing load balancing for one WEB APP-1 and VIP is configured.
VPN - SSO is configured for APP-1 with one layered VIP.
Issue
If we are not doing SSL offloading on load balancer, SSO for APP-1 works fine through VPN on mobile , laptops. But if we enable SSL offloading on load balancer SSO does not work on mobile device (It works on laptops).
Query
How SSO can be achieve on mobile devices for APP-1 through VPN if SSL offloading is enabled on loadbalancer ?
- Arnaud_Lemaire
Employee
Hello Rupesh,
you may need to use and irule in order identifying direct users from vpnssl ones. you have a example here for ssl profile :https://devcentral.f5.com/wiki/iRules.SSL__disable.ashx
