VLAN GROUP , ARP ISSUE, and can't add peer authority device
Dear all.
I wonder that what determine VG mac address(peer) in fdb table, when i configure vlangroup redundant system.
Is there any criteria ??
and..
when the vlans(ex, in) are included in vlangroup, why i can't add peer authority device.
I type the peer addres(peer self ip) and click retrieve device information button.
but can't get peer information just hang clock niddle.
why? is this normal?
- Kevin_K_51432Historic F5 Account
Hi Sunkwan, Looks like to establish trust you must use the management IP address (not self IP):
=========================================================== Establishing device trust Before you begin this task, verify that: On the Main tab, click Device Management > Device Trust, and then either Peer List or Subordinate List. Click Add. Type a device IP address, administrator user name, and administrator password for the remote BIG-IP device with which you want to establish trust. The IP address you specify depends on the type of BIG-IP device: If the BIG-IP device is a non-VIPRION device, type the management IP address for the device. If the BIG-IP device is a VIPRION device that is not licensed and provisioned for vCMP, type the primary cluster management IP address for the cluster. If the BIG-IP device is a VIPRION device that is licensed and provisioned for vCMP, type the cluster management IP address for the guest. ================================================From
Hope this offers some help, Kevin
- Sunkwan_Kim_147
Thanks, Kevin.K. i have used self ip to establish device trust .. but it works~ in manual , recommended configuration is use management-ip when establish device trust .. right? many thanks .
Hi Sunkwan, I notice two things in the manual concerning the importance of management-ip:
This from above:
"If the BIG-IP device is a non-VIPRION device, type the management IP address for the device."
And this from the DSC prerequisite worksheet:
"Management IP addresses Each device must have a management IP address, a network mask, and a management route defined."
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-device-service-clustering-admin-11-5-0/3.htmlunique_1627883324
Hope this is helpful, Kevin
