gmjoen_33163's avatar
gmjoen_33163
Mar 04, 2010
virusscanning using a proxy
We are using our LTM to loadbalance traffic for two app.servers. The traffic is soap/xml and works very good.
Now we would like to introduce a virusscanning solution. We are considering an appliance box which then will act as a proxy.
So the question:
I cant see any where in the LTM configuration that there is a possibility to specify a proxy for a certain node or pool.
Is there such a parameter somewhere? Is there some other way to route the traffic via the appliance box? do you think it would be possible to create an irule to send the traffic via the proxy server?
Regards,
Gaute
  • hoolio's avatar
    hoolio
    Hi Gaute,
    I've heard vague references to F5 considering a tie-in with an antivirus company so you could potentially do virus scanning locally on LTM. You might check with your F5 account rep to see if there is anything more concrete about this now.
    Else, you could try to send a full payload or HTTP parameter to a sideband AV server for validation, but you'd be limited to 4Mb--so I don't think there is a practical way to do this with LTM right now. See this post for details:
    Virus scan attachments
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=31&tpage=1&view=topic&postid=3081430847
    Aaron
  • I'm not sure how efficient it would be, but it's possible. Deb wrote an article on making external calls a while back:
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=105 Click here
  • LOL... Nope, just carelessness. I try to post only as citizen_elah, but sometimes I'm testing with different accounts and forget.
