Racharla_Chandr's avatar
Racharla_Chandr
Dec 20, 2015
Virtual Edition with Lab Licence
Hi All,
  1. Can we setup up HA cluster pair with f5 VE using Lab licence?
  2. What is the max number of SSL TPS in Lab licence?
  3. Is it true that i can upgrade to version 13.X using my Lab license?
Thanks for any inputs.
Regards, Chandu
  • nathe's avatar
    nathe
    Racharla,
    Can we setup up HA cluster pair with f5 VE using Lab licence? - Yes I believe you can. Something you couldnt do with the f5 LTM Trial Edition.
    What is the max number of SSL TPS in Lab licence? - I can't see it documented but my feeling is it would be 500 SSL TPS.
    Is it true that i can upgrade to version 13.X using my Lab license? - Well, TMOS v13 isn't out at the moment, the latest is v12, but yes, you should be able to run the latest version on offer.
    Hope this helps,
    N
