MyWebsiteAdvise's avatar
MyWebsiteAdvise
Mar 23, 2008
Virtual Current Connection Parameter ?
Hello,
Is there a parameter that return the number of concurrent connection of virtual ?
I'm trying to create an irule that will accept 100 connection on virt only.
I did find some connection limit irules, but I prefer something shorter and efficient.
Thanks,
Alex Webs
  • Hi Alex,
    I haven't found a better way then what other's have posted already for you specific scenerio. If you want something straight forward, w/o effort, there is a setting on the virtual server for limitting concurrent connections.
    /CB
  • Hi,
    I find nice iRule that will limit connections.
    Someone knows what will the load on f5 with this script ? I am planning to limit one of the virtuals to 14000 connections and redirect all new connection to another url.
    I want to use this script:
    rule session_limit {
    when RULE_INIT {
    set ::total_active_clients 0
    set ::max_active_clients 50
    ; If persistence cookie already exists,
    ; allow persistent connection without incrementing counter
    if { [HTTP::cookie exists "BIGipServerhalifax"] } {
    pool halifax
    return
    ; If no cookie, check for URI link parameter
    ; & redirect if present
    if { [HTTP::uri] contains "linkID=halifax" } {
    HTTP::redirect "http://pleasehold.evenue.net/bigip/nocookies.html"
    return
    ; Still no cookie
    ; Check limit vs. active
    ; Allow in if there's room, and incr counter for this new cnx
    if { $::total_active_clients < $::max_active_clients } {
    incr ::total_active_clients
    pool halifax
    return
    ; otherwise redirect
    HTTP::redirect "http://www.yahoo.com/"
    return
    when CLIENT_CLOSED {
    incr ::total_active_clients -1
    Is there any other recommended script to limit connection on virtual ?
    Thanks,
    Alex Webs
  • Hi,
    You have an article about how to evaluate performance of an iRule on a BIGIP: Click here
    Otherwise this script may be the best method to evaluate how many connections you have on a VS.
    HTH
