mfkk531_168091
Mar 15, 2017Viprion vcmp host using primary blade IP as source to contact TACACS server, Instead of Cluster IP
Hi
This is causing the authentication to fail. Where can i adjust this within the f5 so that it uses the cluster IP when reaching out to tacacs server. and NOT use the blade IP?
Thanks in advance!
