Zdenda's avatar
Zdenda
Icon for Cirrus rankCirrus
May 30, 2016
Viprion overrides management IP setup through tmsh
Hi, have blade 2250 in chasses 2400 running 11.5.3 HF2 and I need to change mgmt IP. I am connected via console and using these commands:
delete sys management-ip 192.168.2.10/20
create sys management-ip 1.2.3.4/24
But when I use show sys management-ip, I still see the original one. I tried to save config after removal of old mgmt IP, reboot whole chasses, but nothing works.
Thanks for any advice, Zdenek
  • You do not need the delete command. You can just modify the IP via TMSH, the previous one will be over-ridden naturally.
    Assuming your blade 2250 is in slot 3, you can change it's mgmt IP (aka. cluster member IP address) as follows:
    1. Modify Mgmt.IP:
      tmsh modify sys cluster default members { 3 { address 1.2.3.4 } }
    2. Save config:
      tmsh save sys conf
    (note you must do these changes from your primary blade)
    • Zdenda's avatar
      Zdenda
      yeh, I just found it as well, my bad - I have too short memory :) Thanks Anyway
    1. Modify Mgmt.IP:
    2. Save config:
      tmsh save sys conf
    • Zdenda's avatar
      Zdenda
