viprion_cahssis_issue or blade issue
Hi; I have two viprion c2400 chassis .Each chassis has two blade b2100. firstly I put both blade on the same chassis and I did configuration. but then I removed from one of them and I put an other chassis for Failover testing but I didn't to configuration also I could not manage on the https:// (gui) but When I connected to cli I saw some errors mesage e.g.: root@bld:/S1-(none)-S:INOPERATIVE] config ,snmpd[5314]: error on subcontainer 'ia_addr' insert (-1), snmpd[5314]: IfIndex of an interface changed. Such interfaces will appear multiple times in IF-MIB. now what Must I do What is your suggest? thanks for your support and help
- nitass
Employee
for the error, is this relevant?
sol12136: The snmpd process produces debug level syslog messages when the BIG-IP host subsystem interfaces eth0 and eth0.1 have the same IPv6 address
http://support.f5.com/kb/en-us/solutions/public/12000/100/sol12136
for the managment, have you tried cluster member ip address (blade ip address)?
