Karthik_Kumaran
Jan 14, 2015Viprion - check blade uptime
Is there a tmsh command that can show the uptime of the individual blades in a Viprion??
- Brad_Parker
Cirrus
I believe from a bash prompt
will display this. You should log into the management IP of the blade you want.uptime - Karthik_Kumaran
'uptime' from the bash prompt displays only the uptime of the whole chassis. i could not get the uptime of individual blades
- Brad_Parker
Cirrus
are you expecting them to be different? Do you have individual IPs for managing each blade separately and SSH into each individual?
- Jim_43841Historic F5 Account
Uptime from the bash prompt gives the uptime of the blade. If you wish to see them all you may run clsh uptime or do something like ssh slot1 uptime; ssh slot2 uptime; ssh slot3 uptime; ssh slot4 uptime
