SSHSSH_97332's avatar
SSHSSH_97332
Nov 19, 2012
VIP with same IP of Pool
can i create a standard VS with the same IP as its pool member :
VIP : 10.10.10.10
Pool member IP : 10.10.10.10
The idea is that i want t
i cannot use forwarding VS because i want to configure RHI ( route advertisement ) on the VS , which is not available on Forwarding VS .
  • If the Virtual Server and Pool Member are on the same VLAN, I wouldn't think this will work as ARP would get rather confused. However, if clients are routed to the VS (so no ARP is used), it might do, assuming the GUI lets you do it.
  • i tested on V10.2 & it was accepted at GUI , but not sure if it will be accepted with Version 11
