Charles_Lamb's avatar
Charles_Lamb
Jul 07, 2017
VE not reporting stats in traffic summary and unable to reset interface counters
I am migrating a ha-pair from 6900s to VE(VMware). The first device went off without a hitch. The second...
I promoted the second device to active after migrating to VE and I started looking at "Traffic Summary" to validate that the device was not black holing traffic. While the device was in standby I was getting a throughput average of about 900k. After I promoted it to active it started to go up to 10mb and then everything dropped to 0.
I have never seen these numbers at 0 before so I jumped into the cli and ran "tmsh show net interface" then "reset-stats net interface" and the show again. The stats did not reset...
I ran a tcp capture and I am most certain receiving a ton of traffic. It seems to be a glitch in whatever process is generating the statistics. I tried restarting statsd with no effect. I did an mcpd reload. The Traffic Summary responded for about 60 seconds and then everything dropped to 0 again and I had the same problem resetting stats.
Has anybody else run into this problem? Found a known bug on it?
Thanks! -C
root@(MY-F5)(cfg-sync Changes Pending)(Standby)(/Common)(tmos) show net interface
Net::Interface
Name  Status    Bits    Bits    Pkts    Pkts  Drops  Errs     Media
                  In     Out      In     Out
1.1       up  137.6G    8.0G   38.8M   15.6M      0     0      none
1.2       up    8.1G    6.5G    7.2M   11.1M      0     0      none
1.3       up    5.1G    2.8G    5.0M    1.7M      0     0      none
1.4       up    2.0G    1.9G    2.1M    2.8M      0     0      none
mgmt      up  356.5M  597.4M  103.6K  140.7K      0     0  100TX-FD
root@(MY-F5)(cfg-sync Changes Pending)(Standby)(/Common)(tmos) reset-stats net interface
Net::Interface
                  In     Out      In     Out
  • There are no recent BZIDs on this behavior, and none that seem to exactly match what you are describing. I would recommend opening a support case to get this resolved.
