Ryan_80308
Jun 17, 2008/var/log/ltm spew after forced failover
Hi all,
I have a pair of BIG-IP LTM 1500's in active/standby. I just forced the active unit into standby to perform maint. on it, and now the newly "promoted" unit is spewing log entries into /var/log/ltm every second.
Jun 17 22:50:03 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
Jun 17 22:50:03 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.100.5:1028 established.
Jun 17 22:50:04 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
Jun 17 22:50:04 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.100.5:1028 established.
Jun 17 22:50:05 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
Jun 17 22:50:05 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.100.5:1028 established.
Jun 17 22:50:06 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
Jun 17 22:50:06 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.100.5:1028 established.
Jun 17 22:50:07 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
Jun 17 22:50:07 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.100.5:1028 established.
Jun 17 22:50:08 tmm tmm[1576]: 01340001:3: HA Connection with peer 192.168.200.5:1028 established.
2 questions:
1. Why?
2. How do I disable it?
Thanks,
Ryan Schwartz
- Ryan_80308
Here's the settings I've got for logging. - hoolio
The error indicates the two units cannot establish a TCP connection with each other using the failover IP addresses. If one unit is still staying standby, I'd guess you're using serial cable failover. Try checking SOL6065 for a fix:
SOL6065: Error message: HA Connection with peer lost
https://support.f5.com/kb/en-us/solutions/public/6000/000/sol6065.html
Aaron - Thuchapon_92030
i already config failover IP address of the peer unit in the Primary Failover Address Peer text box
and them also can synchronize together
and them have same version
but bigip sill log "Error message: HA Connection with peer lost" .... how i can do ? plzzz tell me. - hoolio
Hi Thuchapon,
You can open a case with F5 Support to get help troubleshooting this issue.
Aaron
