V4 to v11 irule assistance required
Hi, could you assist me in the following irule conversion from version 4 to version 11.
Version 4 Irule:
rule test{
if (tcp_content contains "test") {
use pool test_pool
else if (tcp_bytes_collected < 50) {
accumulate
else {
log "Unrecognised test discarding ${client_addr}"
discard
This is what i have so far but accumulate was removed in 9.3, can you help me with the correct rewrite to v11.
when CLIENT_DATA {
if { [TCP::payload] contains "test"} {
pool test_pool
elseif { [TCP::collect] < 50 } {
TCP::release
accumulate
else {
log "Unrecognised test discarding [IP::client_addr]"
discard
Regards,
Carl
- hoolio
Hi Carl,
Can you try this?when CLIENT_ACCEPTED { Check if the first packet contains "test" if { [TCP::payload] contains "test"} { pool test_pool } elseif { [TCP::payload length] < 50 } { Collect at least 50 bytes. This triggers CLIENT_DATA when at least 50 bytes have been collected. TCP::collect 50 } else { log "Unrecognised test discarding [IP::client_addr]" discard } } when CLIENT_DATA { if { [TCP::payload] contains "test"} { pool test_pool Release collected data TCP::release } else { log "Unrecognised test discarding [IP::client_addr]" discard } }
Aaron - Carl_28880
Hi Aaron,
Thanks for the reply, could you help me understand why i need to have both client_accepted and client_data, will client_accepted not be the equivalent of the v4 irule or am i right in thinking i need the client_data to then release what was collected in the accepted.
I will test however and let you know.
Thanks for the help. - What_Lies_Bene1
I think you just need this for the CLIENT_ACCEPTED event;if { [TCP::payload length] < 50 } { Collect at least 50 bytes. This triggers CLIENT_DATA when at least 50 bytes have been collected. TCP::collect 50 } - hoolio
When you have a TCP profile on a virtual server, CLIENT_ACCEPTED is triggered when the client establishes a connection with the virtual server. You'll have the first packet's worth of payload available in the CLIENT_ACCEPTED event. This should be more than 50 bytes. You can check how much payload there is using [TCP::payload length]. If you want to inspect more than the data available in CLIENT_ACCEPTED you can call TCP::collect X and then check [TCP::payload] in CLIENT_DATA.
Aaron
