using the same certificate on another big ip system on a different region
I have a SSL certificate in one region in F5 and can i use the same in another region f5 system through a chain ?
- oscarnet_69487
HI
check it!
Overview of BIG-IP device certificates
if you have dcs in f5 it is will be use it
BIG-IP Device Service Clustering
have a good day!
- Samir_Jha_52506
Noctilucent
I guess, Its SSL Certificate for URL/HOST? Yes
We can use URL/FQDN SSL certificate to other LB. Archive URL SSL certificate from one LB & import SSL certificate to Other LB. Hope it is clear.
- Ryannnnnnnnn
Altocumulus
Can you please clarify what you mean by "one region in F5"?
