rdessert_76127's avatar
rdessert_76127
13 years ago
Using switch vs if to clean up irule
I'm attempting to clean up an irule that currently uses lots of "if" statements and want to use the "switch" statement instead. I've attempted to format the iRule as follows, but I cannot seem to get the syntax correct.
Any assistance is much appreciated!
Redirect to www.site.org
switch -glob [string tolower [HTTP::host]] {
"site.org" -
"site.com" -
"www.site.com"
HTTP::respond 301 Location "http://www.site.org[HTTP::uri]"
Match uri patterns and redirect to https
switch -glob [string tolower [HTTP::uri]] {
"/uri1*" -
"/uri2*" -
"/uri3*" -
"/uri4*" -
"/uri5*"
log local0.alert "https redirect:[HTTP::host]-[HTTP::uri]-[HTTP::path]"
HTTP::respond 301 Location "https://[HTTP::host][HTTP::uri]"
return
Match uri's and send traffic to pool
log local0.alert "BEGIN Host:[HTTP::host]-[HTTP::uri]-[HTTP::path]"
"/uri10/*" -
"/uri11/*" -
"/uri12/*" -
"/uri13/*" -
"/uri14/*" -
"/uri15*"
log local0.alert "pool1 Host:[HTTP::host]-[HTTP::uri]"
pool pool1
return
default {
pool pool2
  • Looks to me like you are missing a closing curly brace after each of the first two switch statements, and an extra one after the last switch statement. Does this work?
    "site.org" -
    "site.com" -
    "www.site.com"
    "/uri1*" -
    "/uri2*" -
    "/uri3*" -
    "/uri4*" -
    "/uri5*"
    return
    "/uri10/*" -
    "/uri11/*" -
    "/uri12/*" -
    "/uri13/*" -
    "/uri14/*" -
    "/uri15*"
    pool pool1
    return
    default {
    pool pool2
  • That worked perfect! The rule saved successfully. I'm still working on getting proper syntax down :-)
    Thanks for the help.
    Rich
  • hoolio's avatar
    hoolio
    You should also add a return after this line to ensure that you don't continue evaluating the rule code after sending a redirect:
    return
    Aaron
