Using SSO between multiple applications
We have published a couple of applications, namely Citrix, OWA and Sharepoint (All through the use of iApps). All three applications are making use of Active Directory authentication on the same domain. We would now like to allow the users to be able to authenticate on a single application and from there be able to access the other two applications without the need to re-authenticate.
I have tried to follow other threads within the forum but with no success.
Can anyone help please?
- Matt_Dierick
Employee
I suppose, if you use iApp, that you have 3 different APM polices ? In order to use SSO, you need to merge the 3 applications on the same VS/policy. SSO is based on the APM session and the username/passwords are stored in session variables.
Hope this help. Matt
We have this implemented on our F5s with multiple APM policies.
We have citrix.example.com, owa.example.com and ADFS.example.com
In the SSO configuration of the APM policy there is a domain cookie setting, that is set to *.example.com in each APM policies
Works a treat for us
Actually, set the domain cookie to .example.com
You can go from webtop to another site without issue.
You need to make sure you actually sign in otherwise that error occurs
