Using SNMP to monitor LTM traffic
Hello ,everyone! im Jepson, i want to use SNMP to monitor BIGIP LTM. there are two LTM 1600 in my company , and i have done a HA between them. now i want to monitor the ISP traffic , so i think i need to monitor the ifInOctets and ifOutOctets of export ports on the twoLTMs,when i snmpwalked them ,it worked ,and i could get their results,but when i used zabbixto monitor these parameters, the graphs showed the traffic was just 100+ bps, and i also tested other kind of devices, it produced normal traffic graphs with mbps traffic
so,can anyone tell me why the export ports of LTM return just 100+ bps traffic, did i monitor the wrong port ,or i need to monitor the LTM export vlan ?
- Max_Q_factor
Cirrocumulus
I think I am a bit confused of what you are asking but have you looked at this zabbix template?
https://www.zabbix.com/forum/showpost.php?s=244bf9a4446c66a3e64365683018cf6f&p=83533&postcount=8
