amit_128525's avatar
amit_128525
Dec 13, 2013
using old SSL certificate
hello , We have a existing certificate from certificate autohirty , we are mighrating our network and we are planning to use it in new F5 enviroment which we have , just wanted to know if I can use existing certificate if it has not expired . On F5 I have created a CSR and exported it it has key I need to upload a certificate now , Can i import this existing certificate . Hope I am able to explian the query
  • you can't connect this existing certificate to some random new key. you will have to export the current key and certificate from where ever you are using it and then you can import both to the F5.
