Using LTM for network forwarding
Our data center architecture has a pretty standard model, with an "internal" network and a "DMZ". Our internal network does not have a direct route to the Internet. However, I have LTMs in our DMZ that can access the Internet directly. We have a server in our internal network running Microsoft Office 365 "Hybrid services" that needs to access a number of Microsoft Office 365 public networks, and I am being asked to facilitate this connectivity with our LTM. But given my lack of networking knowledge, I don't quite understand how I might configure the LTM to do this. I get a bit lost when it comes to how the different VS types function.
I was hoping someone might be able to help me understand at a high lievel what we would need to do in our network gear, and on the LTM, to enable this communication?
- Thomas_Gobet_91
So you can't define a static route directly from your Microsoft server. You have to define a route on your internal router.
I can suggest you to make a Policy Based Routing (PBR) it will avoid you to change a lot of thing on your configuration.
For sure your problem isn't part of your F5 configuration.- smp_86112
Sorry, but I don't understand what PBR means or what the implications are. What I really need to understand is whether or not the F5 can facilitate this communication, and if so, how would I do it? It's not really my decision about how much work is too much - I just need to communicate what I would need to do. But I'm still unsure about that. If we configured our internal routing infrastructure to point each of the published Microsoft networks at our F5, could I create IP Forwarding Virtual Servers for each of those networks and enable SNAT? I realize the complexity and the amount of Virtual Servers that would need, but technically speaking would that work?
- Thomas_Gobet
- Thomas_Gobet
What you need to do is to add a route on your internal router.
Traffic coming from your Microsoft server has to be routed to your BIG-IP.
Then once it will be done, you will have to create a forwarding virtual server and enable SNAT.
Be careful your BIG-IP has to know how it can reach the Microsoft server. You can add a static route pointing to your internal router, or you can enable auto last hop.Even if it's not the best solution, it's possible to make it work.
- smp_86112
Yes, the F5 can reach both the internal server and the public internet cloud. So assuming we have routes on our internal router for all these public cloud networks pointing at our F5, I'm trying to understand all the various forwarding configuration options I've got. It sounds like I could create a forwarding VS for each corresponding public cloud network and enable SNAT. Painful, but possible. Based on a comment above, it sounds like I could apply an iRule to my existing wildcard VS and SNAT traffic with a destination of these public internet clouds. I don't want to do this either, but possible. Are there other VS types or properties on the F5 that would allow this internal server to get out to a public network?
If the connection was point-to-point, this would be simple. The kicker for me is that the destination is a network, not a single endpoint. That throws a non-networking guy like me for a loop.
- Thomas_Gobet_91
You don't need to create iRule, you can specify source IP which will match your virtual server.
So you can specify a forwarding virtual server with 0.0.0.0/0 as destination and in Source IP the Microsoft server's IP.
That's all ;)- smp_86112
Whoa, I don't understand at all what you have described or how it would work. Can you fill in the gaps a bit there?
- Thomas_Gobet
- Thomas_Gobet_91
Don't know where you loosed me... Can you tell me which version you're running on ?
It could be a reason that you don't understand where we can define a source IP on a virtual server.- smp_86112
I'm running 10.2.4HF6. Again, I appreciate your willingness to stick with me. > you don't understand where we can define a source IP on a virtual server That's possible if not likely, we could be talking about VS properties or behavior I've never used or thought about before.
- Thomas_Gobet
- Thomas_Gobet
On 10.2 you don't have the "Source IP" directly from VS properties.
You have to use iRule on your forwarding virtual server to apply SNAT only if the source IP is your Microsoft server.when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals "your_server's_IP"] } { snat automap } }- smp_86112
I get the iRule, but what VS are you suggesting I apply it to?
- Thomas_Gobet_91
