Using iRules with DTLS
Per F5 support, I've implemented DTLS for our Network Access APM VPN connections. The problem is that I have an irule that evidently needs an HTTP profile to work and I don't have that available in my DTLS virtual server. Here is the error I'm getting:
01071912:3: ACCESS::restrict_irule_events in rule (/Common/EmoryLogging) requires an associated ACCESS profile on the virtual-server (/Common/EmoryVPN_DTLS_vs).
Any ideas on how to fix this? I'll post my irule below.
- aefting
Altostratus
Here is my irule:
when CLIENT_ACCEPTED { This is required to allow HTTP_REQUEST event to key off of APM internal URI ACCESS::restrict_irule_events disable }
when ACCESS_POLICY_COMPLETED {
After VPE policy is completed, check if user has been denied. A session variable of "session.custom.denyreason" is set in the VPE to provide an errorcode for logging purposes Note that ACCESS::policy result isn't evaluated in the ACCESS_SESSION_CLOSED event. Placing the logging here removes the need to create a new session variable containing the result. if {[ACCESS::policy result] equals "deny"} { catch {set starttime [ACCESS::session data get "session.user.starttime"]} catch {set userip [ACCESS::session data get "session.user.clientip"]} catch {set username [ACCESS::session data get "session.logon.last.username"]} catch {set sessionid [ACCESS::session data get "session.user.sessionid"]} catch {set assignedip [ACCESS::session data get "session.assigned.clientip"]} catch {set assignedresources [ACCESS::session data get "session.assigned.na.current"]} catch {set geolocationcountry [ACCESS::session data get "session.user.ipgeolocation.country_name"]} catch {set platform [ACCESS::session data get "session.client.platform"]} catch {set avstatus [ACCESS::session data get "AVcheckFailed"]} catch {set fwstatus [ACCESS::session data get "FWcheckFailed"]} catch {set browser [ACCESS::session data get "session.client.type"]} catch {set version [ACCESS::session data get "session.client.version"]} catch {set url [ACCESS::session data get "session.server.network.name"]} catch {set macaddr [ACCESS::session data get "session.last.usermac"]} catch {set denyreason [ACCESS::session data get "session.custom.denyreason"]} log local0. "Denied ([clock format $starttime -format {%d %b %Y %T %Z}]|$assignedresources|$sessionid|$username|$userip|$assignedip|$geolocationcountry|$avstatus|$fwstatus|$platform|$browser|$version|$url|$denyreason|$macaddr)"} } when HTTP_REQUEST {
The "session.assigned.clientip" is assigned after ACCESS_POLICY_COMPLETED and before ACCESS_SESSION_CLOSED. In order to capture it, we key off of an internal URI hit by client when VPN is established. We wait a few seconds for the lease pool IP address to be assigned and then log the address here. if { [HTTP::uri] starts_with "/myvpn?sess=" } { after 5000 { catch {set starttime [ACCESS::session data get "session.user.starttime"]} catch {set userip [ACCESS::session data get "session.user.clientip"]} catch {set username [ACCESS::session data get "session.logon.last.username"]} catch {set sessionid [ACCESS::session data get "session.user.sessionid"]} catch {set assignedip [ACCESS::session data get "session.assigned.clientip"]} catch {set assignedresources [ACCESS::session data get "session.assigned.na.current"]} catch {set geolocationcountry [ACCESS::session data get "session.user.ipgeolocation.country_name"]} catch {set platform [ACCESS::session data get "session.client.platform"]} catch {set avstatus [ACCESS::session data get "AVcheckFailed"]} catch {set fwstatus [ACCESS::session data get "FWcheckFailed"]} catch {set browser [ACCESS::session data get "session.client.type"]} catch {set version [ACCESS::session data get "session.client.version"]} catch {set url [ACCESS::session data get "session.server.network.name"]} catch {set macaddr [ACCESS::session data get "session.last.usermac"]} catch {set denyreason [ACCESS::session data get "session.custom.denyreason"]} log local0. "Established ([clock format $starttime -format {%d %b %Y %T %Z}]|$assignedresources|$sessionid|$username|$userip|$assignedip|$geolocationcountry|$avstatus|$fwstatus|$platform|$browser|$version|$url|$denyreason|$macaddr)" } }}
- Philipped
I see your post is 4 months old and I am trying to find a solution to this issue as well.
Have you found a solution or are you still looking for one?
