Peter__Chan_109's avatar
Peter__Chan_109
Oct 26, 2005
Using iRules to do source port and IP address persistence
Hi folks,
I'm trying to write an iRule to do a persistence to the same node by using the source IP and port.
The syntax is as follows:
when CLIENT_ACCEPTED {
if {[TCP::client_port] and [IP::client_addr] !=0} {
persist uie [TCP::client_port]
Please anyone help comment and correct on it.
Thanks,
:P
  • Hi Guy,
    Thank you for your help and I have tested with the customer and it sounds GREAT.
    :P
