Shohab_Baig_841
May 03, 2007Using I-rule to redirect traffic to https
Hi - We have approx. 20-25 pages on our website which needs to be secured. I am using following I-rule to do it. Following is a sample what I am writnng to make those pages secure:
switch -glob [HTTP::uri] {
HTTP::redirect "https://www.efreightquote.com/membersite/ACH/Default.aspx"
"/MakePayments.asp" {
HTTP::redirect "https://www.efreightquote.com/membersite/ACH/MakePayments.asp"
"/Signin.aspx" {
HTTP::redirect "https://www.efreightquote.com/Signin.aspx"
"/PaymentReport.asp" {
HTTP::redirect "https://www.efreightquote.com/membersite/ach/PaymentReport.asp"
"/ApproveInvoices.asp" {
HTTP::redirect "https://www.efreightquote.com/membersite/ach/ApproveInvoices.asp"
"/AuditInfo.asp" {
HTTP::redirect "https://www.efreightquote.com/membersite/ach/AuditInfo.asp"
"/BilledInfo.asp" {
HTTP::redirect "https://www.efreightquote.com/membersite/ach/BilledInfo.asp"
"/CreditCard.aspx" {
HTTP::redirect "https://www.efreightquote.com/QSTP/CreditCard.aspx"
"/Default.aspx" {
HTTP::redirect "https://www.efreightquote.com/Default.aspx "
default {
use pool www_freightquote_com
Its really slowing down the website response. could you recommend any better way to do it.
Shohab
- Shohab_Baig_841
I have fixed signin.aspx page but that doe snot solve my problem. Can anyone take a look at the rule and recommend which can boost the performance.
Shohab - Deb_Allen_18Historic F5 AccountCheck out this post for an example of solving the same problem using "findclass" instead of "switch". Not sure if it will improve performance, but it's worth trying:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=14031&ptarget=14072 (Click here)
Since you want to switch on the entire URI, instead of just the host & part of the URI, just replace these 2 lines:
with this one:set req "[HTTP::host]/[getfield [HTTP::uri] "/" 2]" set redir [findclass $req $::TURL_List]set req "[HTTP::host]/[getfield "/" 2]" set redir [findclass [HTTP::uri] $::myRedirects " "]
HTH
/deb
