Martin_Kaiser_1's avatar
Martin_Kaiser_1
Oct 20, 2005
using getfield to split up URIs
Hi there,
can anyone of you show me the correct syntax for using the function getfield in an iRule?
What I want to do is split up an URI like "/webstart/portal/customer_id/some/more/fields" and extract the field customer_id, that is always in the third position. The value should be stored in a variable that can be used again later for dynamically choosing pools or redirects in case of LB_FAILED.
Thanks in advance!
Regards,
Martin
