ozdemircili_696's avatar
ozdemircili_696
Jan 21, 2011
Using F5 as NTP deamon
Iºd like to use F5 as a Time server. Has anyone any experience on this? F5 seems quite stable and I prefer a hardware based system than using a regular server.
Making the changes in ntp.conf using the shell and giving permissions as a regular unix system will work?
Thank you.
  • hoolio's avatar
    hoolio
    It wouldn't be supported by F5, but it should work. You'd also need to allow port 123 on the self IP(s) allow list for the self IP(s) that you want to allow client access to.
    Aaron
  • As Aaron said, this is possible but I really don't like the idea.
    Since most devices accept more than 1 multiple server, reliability shouldn't be a huge issue. Since there are plenty of open source solutions that could be run on a VM, I'd prefer using servers. We have quite a few boxes dedicated to "management services" like this...syslog, dns, ntp.
  • I've always preferred serving ntp from the client/server l3 gateways so the bulk of queries remain local. If it is something you change in the system configuration, note that this will not survive a hotfix or upgrade.
  • Posted By Jason Rahm on 01/25/2011 11:09 AM
    How does the upgrade process work with files like ntp.conf? Since ntp.conf gets edited when defining ntp servers, it wouldn't get blown away, would it? Or does the box just re-create the file with the only contents being the NTP servers defined via the GUI/CLI?
  • hoolio's avatar
    hoolio
    The system daemon file configuration can be customized in the bigip_sys.conf using include files. If you manually edit the files, they will probably get overwritten during an upgrade.
    Here's an example you know of from Deb about customizing the syslog-ng config. The same concept can be used for ntp, sshd, etc.
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=155
    Aaron
