Using Diameter Commands
Hi guys,
May be you are more awake that myself but i am currently stuck with the following problematic with Diameter:
- OCS needs to get additional 3GPP AVPs on any CCR it receives from BIGIP
- 3GPP AVPs are known from Radius Accounting
- BIGIP needs to insert the 3GPP AVPS to each CCR with the grouped "Service-Information" AVP:
[Service-Information = [PS-Information = [3GPP-Charging-Id = <3GPP-Charging-Id M V 10415 00:00:00:00/>] [3GPP-PDP-Type = <3GPP-PDP-Type M V 10415 0/>] [PDP-Address = ] [3GPP-GPRS-Negotiated-QoS-Profile = <3GPP-GPRS-Negotiated-QoS-Profile M V 10415 06-00000000000000000000/>] [SGSN-Address = ] [GGSN-Address = ] [CG-Address = ] [3GPP-IMSI-MCC-MNC = <3GPP-IMSI-MCC-MNC M V 10415 xxxxx/>] [3GPP-GGSN-MCC-MNC = <3GPP-GGSN-MCC-MNC M V 10415 xxxxx/>] [3GPP-NSAPI = <3GPP-NSAPI M V 10415 x/>] [Called-Station-Id = ] [3GPP-Selection-Mode = <3GPP-Selection-Mode M V 10415 x/>] [3GPP-Charging-Characteristics = <3GPP-Charging-Characteristics M V 10415 0000/>] [3GPP-SGSN-MCC-MNC = <3GPP-SGSN-MCC-MNC M V 10415 00000/>] [3GPP-MS-TimeZone = <3GPP-MS-TimeZone M V 10415 00:00/>] [3GPP-User-Location-Info = <3GPP-User-Location-Info M V 10415 00:00:00:00:00:00:00:00/>] [3GPP-RAT-Type = <3GPP-RAT-Type M V 10415 00/>] ] ]
How would you do it with the diameter commands ? Any elegant solution ?
How do you insert all the 3GPP AVPs within the Grouped "PS-Information" AVP?
Thanks for your help
Regards
- Arnaud_Demene_6
Thanks a lot. This is exactly what i wanted. It may be a good idea to use this example in the iRule Wiki to illustrate the use of Diameter commands. Thanks again you helped me a lot ;O)
