Using 3 branch in a decision box - APM
Hi all,
We are using a 2 branch decision box to authenticate users in APM Policy with 2 differents authentication methods. We want to use a third way to authenticate users, but unfortunately, in the Properties tab of the decision box, there is a customisation part. But, there is only option1 and option2, i do not see option3 appear.
How can i make it work ?
- kunjan
If you want to display the 3 options similar to 2 options case for 'Decision Box', it's not possible without some advanced customization effort. There is feature request for this. You may want to raise support case to increase priority of this.
- khaled83_147377
Ok that was what i was suspecting, is it so hard to customize it ? I thought to do link two decisionbox
- kunjan
I've not tried it. But you can give a try
Access Policy ›› Customization : Advanced ›› < Policy > ›› 'Decision Box'
- kunjan_118660
Cumulonimbus
- khaled83_147377
- kunjan_118660
Cumulonimbus
